View the Distribution Control tab to see the network segment data source on which the protocol distribution statistics are measured. The management IP mentioned as a data source represents the IP that the SNMP agent uses to access the switch.
  1. In the navigation pane, expand Configuration > Serviceability > RMON.
  2. Select Protocol Distribution.
  3. Select the Distribution Control tab.
Distribution Control Field Descriptions
Use the data in the following table to use the Distribution Control tab.
Name
Description
Index
Shows a unique identifier for the entry in the table.
DataSource
Specifies the source of data for this protocol distribution.
DroppedFrames
Shows the total number of frames that the probe receives and drops but does not include in the StatsDropEvents value. This event can occur if the probe is out of resources and sheds the load from this collection. This value does not include packets that were not counted because they had MAC-layer errors.
CreateTime
Shows the value of the sysUpTime when the entry was last activated.
Owner
Shows the entity that configured this entry.
